EPM.ISSU.RollUpgrdSkipCompat
Description
Compatibility checks ensure that an In-Service Upgrade is not performed between releases which are known to be incompatible; however, there may be circumstances where it is desirable to ignore compatibility checks and upgrade anyway. This event is generated to indicate that the rolling reboot is being run without performing compatibility checks.
Remedy
No action required - Informational message only.
Severity
Warning
Message Text
A rolling reboot has been started with compatibility checks disabled.
